DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Is it cheaper to leave Combi boiler on 24/7 or on timer
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
julioarca
from United Kingdom
PostPosted: Sun Feb 24, 2008 8:02 pm Reply with quote
Basically, is it cheaper to run a combi boiler (gas) on low setting over winter 24/7 or is it more economical to have it come on twice a day, morning and night.
Probably 2.5 hrs a morning
and 7-8 hours at night?
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Sun Feb 24, 2008 8:25 pm Reply with quote
It will ALWAYS be cheaper to run something that is switched OFF!!!! You do not get a peak demand charge, and physics in our universe means having something at a higher temperature than its surroundings will need more fuel to do it, and hence more money.
Anyone telling you otherwise doesn't live in this universe, but could have found a channel from another universe where physics works differently.
Back to top
 Alert Moderators
kev25v6
from United Kingdom
Thanked: 2 times
PostPosted: Sun Feb 24, 2008 8:51 pm Reply with quote
I always leave mone on low setting as this keeps the house at 21 degrees which is fine for me. The boiler only kicks in for a short time as the house is always warm where as if the house is cold and you give it full blast heat for those few hours i would guess that you would be spending more in the long run because the house will be constantly heating up then cooling down, meaning you have to have it turned up higher for longer to keep the same temp as a boiler set on low constantly. (Does that make sense?)
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 651 times
PostPosted: Sun Feb 24, 2008 10:15 pm Reply with quote
its always cheaper to run at a temperature when you need it
i recon you will use about 20 to 40 percent more energy keeping a constant temperature
if you allow the temperature to stay constant overnight you pay 100 percent to maintain that temperature
as the temp lowers the heat loss reduces
if you house is average by the time you have lost about 5 degrees in internal temp your 100 percent to maintain temp has reduced to perhaps 20 percent
so thats 6 hrs overnight no input then 40 mins before you get up to full heat and by 1hr full temperature in the room
the actual amount of saving depends on actual heat loss and efficiency of the heating system
Back to top
 Alert Moderators
Bamber gaspipe
from United States of America
PostPosted: Sun Feb 24, 2008 10:35 pm Reply with quote
Use it when you need it. Timer works. icon_wink.gif Discard all the other lectures. icon_wink.gif
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 44 times
PostPosted: Sun Feb 24, 2008 11:04 pm Reply with quote
The hotter something is the more it will lose its heat.
Your house is losing heat at its highest rate for about 10 hours a day. You are proposing to let it lose heat at the highest rate for 24 hours.
Its as ludicrous as leaving your car engine running so its warm when you next want to drive it.
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Sun Feb 24, 2008 11:29 pm Reply with quote
kev25v6 wrote:
............. if the house is cold and you give it full blast heat for those few hours i would guess that you would be spending more in the long run
Your guess is wrong. Mine is not a guess.
If it heats to your normal temperature, then cools when you're not there, then heats up to your normal temperature, it's average will be less that if you have it high all the time.
Well DOES it?
It's no good trying to explain to these people matters of fundamental physics, anymore than it is to get over to most people that Richard Branson with his veggie fuelled 747 is up to anything more than a publicity stunt.
1) Hotter things cost more to keep hot, (except the sun).
2) Bio-fuels will not be a substitute for oil, nor will they have any significant effect on "global warming", even if you accept that it is a man made effect in the first place.
Back to top
 Alert Moderators
julioarca
from United Kingdom
PostPosted: Mon Feb 25, 2008 8:59 pm Reply with quote
thanks guys, guess I understand now
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2525 times
PostPosted: Tue Feb 26, 2008 1:43 am Reply with quote
kev25v6 wrote:
I always leave mine on low setting as this keeps the house at 21 degrees which is fine for me. )
If your low setting gives you 21 ° C then I hate to think what your high setting will give you!
Ever though about using a pullover and setting the house to 18 °C like the teachers and vickars do? Saves your gas bill and the ozone layer!
Tony
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Tue Feb 26, 2008 9:09 am Reply with quote
What's it got to do with the ozone layer?
Back to top
 Alert Moderators
Kes
from United Kingdom
PostPosted: Tue Feb 26, 2008 3:21 pm Reply with quote
If you asked the nearest seven-year-old (before you get arrested) then they would probably say why don't you take a meter reading of your twice a day use, then take one of your all-day use, and take one from the other. I doubt if the seven-etc could spell initiative, though.
I don't have a meter as I don't have gas, but - being interested in any theory that might produce lower fuel bills - I took a few timings of my oil boiler this morning. With the c/h on it fires for just over two minutes in every five, approx 26 mins an hour. On the twice a day setting, allowing for the two 40-min warmups in the morning and evening, the boiler fires for 4.5 hours a day. As the boiler specs say 3.2 ltrs an hour that's 14 litres a day, just about what we use.
So if we left the boiler on all day it would not have the afternoon warmup, but seven hours of 26 mins during the day. The boiler would be on for a total of just over seven hours a day, using 22 ltrs. So twice a day it is.
We also have windows thrown open during the day, and wandering in and out, so I would be a real miserable git if the boiler were chugging away to warm fresh air.
Rgds.
Back to top
 Alert Moderators
Alanka
from United Kingdom
PostPosted: Fri Feb 29, 2008 9:03 am Reply with quote
A house fully warmed up to the required temperature is like a bucket full of water with a hole in the bottom.
They both leak heat (water) at a rate that increases with temperature (water level). The higher the temperature (water level), the faster does the heat (water) pour out through the walls (hole).
Only when it is at outside temperature (empty) does the leaking cease.
To maintain a constant temperature (water level) you have to inject heat (water) at a rate that exactly matches the heat (water) loss, at any particular temperature (water level).
The higher the steady temperature (water level) required, the more heat (water) has to be injected per second.
If you need your house (bucket) up to temperature (full of water) first thing in the morning when you get up, should you keep the house (bucket) full of heat (water) all night?
Or should you switch off and let the heat (water) leak away overnight, and only inject heat (water) to raise the temperature (water level) to what you want just before you rise?
It's easy to see that you'll waste a lot more heat (water) keeping the house (bucket) full -- and the leaks going at full blast -- when you don't actually need to. And this waste will be worse the bigger the leaks.
Cheers,
Big Al
Back to top
 Alert Moderators
[Davey]
from United Kingdom
PostPosted: Fri Feb 29, 2008 9:06 am Reply with quote
Alot of people go on about peak charges for power but.. But I'm pretty sure electric meters do not have clocks in them icon_lol.gif
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 150 times
PostPosted: Fri Feb 29, 2008 10:27 am Reply with quote
Big Al
Thats a good analogy
Back to top
 Alert Moderators
mehran
from United Kingdom
Thanked: 418 times
PostPosted: Fri Feb 29, 2008 10:56 am Reply with quote
Good if you don’t want heat in your house icon_rolleyes.gif we should be getting away from the simple on off controls to comfort and setback
You don’t want your house to plummet to -3 because there is a frost out side? Say 18-21 degrees for you comfort temp (when you’re up and about) and set back 14-16 degrees (for when you’re out or in bed)
Or you can have zones in your house. Take your bedrooms and living area as two different zones. Have the bedrooms have no (or little) heat during the day and at night have the living areas off.
Yes if you have it off you will not use any gas but then you have no heating.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
is it cheaper to reduce rads or boiler temp 18 1000 Mon Dec 06, 2010 12:24 pm
boiler is on the blink is it cheaper to replace than repair? 10 3600 Wed Nov 29, 2006 8:42 pm
Aqualisa or something cheaper ? 2 80 Sun Mar 13, 2011 7:28 pm
Which is cheaper to run 3 420 Mon Nov 06, 2006 11:58 am
Towel Radiator valves - £150?! Help me find cheaper please!! 11 320 Tue Oct 26, 2010 9:36 am
DIYnot
