DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
imerssion switch
This topic originated from the How to page called Fitting a Fused Connection Unit
Click here to return to the page called Fitting a Fused Connection Unit.
  View previous topic :: View next topic
Author Message
actionmal
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 25, 2004 1:44 pm    Post Subject:
imerssion switch
Reply with quote Thanks
I turned on my imerssion swith and the unit blew. This is an old unit 15 years or so with the red iluminated panel.The bulb seems to have blown. There is no fuse in this unit. Does the bulb act as a fuse? Do I replace the whole unit?. What is the fuse rating of this unit?. The fuses in the box all sem ok, Mal
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Aug 25, 2004 6:02 pm    Post Subject:
Re: imerssion switch
I think some clarification is needed (well, it is for me, anyway)
When you say "the unit", what do you mean? Was there a flash or a bang from anywhere?
Do you mean a switch similar to this?:
The bulb would not be a fuse. Does the switch feel the same when you work it? Could it be broken? Do you have the skills and confidence to remove it and check the wiring?
If the "unit" is a switch, it doesn't have a "fuse rating".
Any chance of a photo?
I take it you mean the main fusebox?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
kai
from United Kingdom
Thanked: 5 times
PostPosted: Wed Aug 25, 2004 7:18 pm    Post Subject:
immersion switch
I had a similar problem, so went out and bought a new MK Fused Connection Unit with 13amp fuse (Better Protection), and installed it in place of the old one, and all works fine now.
It is fed from a single 16amp B MCB on a 2.5 sq.mm. cable and is 8 metres long approx.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
wire a two way light switch 3 260 Sat Dec 01, 2007 9:08 am
Re-connecting a double-dimmer switch 6 360 Sat Dec 01, 2007 6:47 pm
single switch/one gang dimmer replaced with 2 gang dimmer 5 460 Thu Nov 29, 2007 5:53 pm
3 gang intermediate switch? 10 1600 Tue Nov 27, 2007 12:31 pm
2G 2W Light switch with wrong switch direction 5 340 Mon Nov 26, 2007 10:23 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
