Radiator not working
24 Mar 2006
Surrey
The radiator in my utility room stopped being hot a few days ago. I tried bleeding it but no air came out, just water straight away. The valve is set to the highest setting and no one has turned it off. All other radiators are working fine.
Any ideas.
If you mean a valve with numbers 1-6 on it, then yes. It is currently on number 6. The valve does turn so does not appear stuck. Do you mean the internal workings are stuck ?
Yes, do a search on this forum - theres lots of advice on unsticking 'em
