DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bosch Exxcel 1200 Express Washing machine - Drum not turning
Goto page 1, 2, 3, 4, 5  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
Ledward
from United Kingdom
Thanked: 1 time
PostPosted: Sat Mar 01, 2008 11:56 am Reply with quote
This is the first time I have used the internet for this type of thing so hoping somebody can help on this problem.
Bosch Exxcel 1200 Washing machine will fill with water but won't do anything else. Can hear the programs being run through and then the water is discharged.
As water will flow in and be pumped out realise this is not a pump problem.
Could it be a motor problem? (replacement motor is £179) so need other ideas before paying out that sort of money.
Reasonable handy can tackle most things but not major knowledge on electrics.
Looking forward to some help.
Back to top
 Alert Moderators
Ledward
from United Kingdom
Thanked: 1 time
PostPosted: Sat Mar 01, 2008 6:58 pm Reply with quote
I am replying to myself here so that hopefully I can help someone else in the future.
After reading various other threads, realised it was probably the bushes in the motor. To change these:
Disconnect electric supply
Disconnect Water supply
Disconnect Drain pipe.
Turn machine upside down
Remove the belt off the fly wheel
Remove the motor by taking the two bolts out towards the back of the motor support arms
The motor then slides out.
Remove the bush that is not near the terminal block
Remove the bush near the terminal block it is easier to unplug the terminal block first.
Replace the bushes and re assemble
Hay Presto - one working machine. total cost £33.17 a bit of hassle and a great deal of satisfaction. Alternative call an engineer Motor £179.64 plus labour say £60. Total £239.64. Saving £206.47 I'm off to the pub!
If I can do it then most people can do it.
Back to top
The following user says thank you to Ledward for this useful post:
paulgowers (17 Mar 2010)
 Alert Moderators
njc
from United Kingdom
PostPosted: Sat Mar 01, 2008 7:14 pm Reply with quote
Hi - I'm just curious: did you manage to buy your replacement brushes in a local shop? (I got mine mail-order as I couldn't figure out what shops might stock them, despite a good bit of net searching...)
ta
Neil
PS: I was assuming you didn't get 'em mail-order as both your posts were today...
Back to top
 Alert Moderators
Ledward
from United Kingdom
Thanked: 1 time
PostPosted: Mon Mar 03, 2008 6:38 pm Reply with quote
Hi Neil,
Just got out the old fashioned Yellow Pages and looked up Electrical Appliances and looked for a Bosch stockist and phone to see if they had the part in stock.
Cheers
Simon.
Back to top
 Alert Moderators
njc
from United Kingdom
PostPosted: Mon Mar 03, 2008 7:42 pm Reply with quote
Back to top
 Alert Moderators
wildgal
from United Kingdom
PostPosted: Mon Mar 10, 2008 11:17 am Reply with quote
Hiya similar prob.... can I ask why the need to turn the washer upside down??? Only I'm trying to have a go at locating these bushes.... but cant get the motor off???
Many thanks x
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 25 times
PostPosted: Mon Mar 10, 2008 5:46 pm Reply with quote
Turning upside down can result in problems with the pressure system.
Do it properly, remove the motor from the rear of the machine, change the carbons, refit the motor.
Not all repairers would fit a new motor. We carry carbon brushes as van stock.
Back to top
 Alert Moderators
Blue_Manc
from United Kingdom
PostPosted: Mon Oct 13, 2008 8:15 pm Reply with quote
Cheers fellas - top advice - mine is sorted now.
Back to top
 Alert Moderators
jbainbridge
from United Kingdom
PostPosted: Sat Dec 20, 2008 3:02 pm Reply with quote
Just to say thanks for the advice in this thread ... £15 and half of Saturday afternoon have resulted in a working machine.
Just in time for Christmas too.
JB.
Back to top
 Alert Moderators
STORM2
from United Kingdom
PostPosted: Fri Feb 13, 2009 9:39 pm Reply with quote
Just replaced the brushes myself on a Bosch Maxx Exxcel 1200 (is one x not good enough for Bosch?)
I was wondering if its normal to be a little noisier on drum revolution with new brushes or have I not aligned the belt properly?
cheers
Back to top
 Alert Moderators
folleyball
from United Kingdom
PostPosted: Sat Feb 14, 2009 4:31 pm Reply with quote
You usually find the machine a little noisier after replacing the brushes.
They just need time to bed in properly.
Back to top
 Alert Moderators
JBFoggy
from United Kingdom
PostPosted: Sun Jun 07, 2009 4:06 pm Reply with quote
Hi, I have a similar problem with a 3-year old machine.
It has not been used more than 20 times during this period since it has been in storage and is now out in Spain with us.
The machine will fill with water (much higher than it normally does) then immediately drain. The drum will not turn on any of the programs although it will operate on the Spin setting.
I assume, therefore, that this is not a problem with the motor/bushes since the Spin program does work.
Could it be something to do with the program circuit board?
Since we are stuck out in the mountains in southern Spain without anyone nearby to help us, it would be great if you clever things could point us in the right direction.
Thanks, Lynda and Joe
Back to top
 Alert Moderators
rocks1
from Turkey
Thanked: 877 times
PostPosted: Sun Jun 07, 2009 4:27 pm Reply with quote
pressure tube come off /blocked pressure chamber .blow though the pipe on the inside of mc .
Back to top
 Alert Moderators
JBFoggy
from United Kingdom
PostPosted: Mon Jun 08, 2009 12:27 pm Reply with quote
Thanks Rocks1
You say that I need to check if the pressure tube has come off or if there is a blocked pressure chamber, then blow through the pipe on the inside of the mc.
I have been searching the internet for a diagram of the machine to show where the above tube/chamber are and haven't been able to find one.
Could you give me a better idea of where these are within the machine?
Many thanks,
JB
Back to top
 Alert Moderators
rocks1
from Turkey
Thanked: 877 times
PostPosted: Mon Jun 08, 2009 2:22 pm Reply with quote
remove the lid and on the right hand side i think, is a clear plastic tube that runs to the bottom of the mc .at the top of the cabinet is a black round pressure switch the tube is attacted to that
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 5
Jump to:
Bosch Exxcel 1200 Express washing machine drum won't turn 2 40 Wed Feb 29, 2012 9:44 pm
Bosch Classixx 1400 Express, drum not turning but motor OK? 7 4100 Mon Feb 14, 2011 8:43 pm
Bosch Exxcel 1200 express washing machine (Burning smell) 2 320 Tue Nov 02, 2010 2:07 pm
Removing front of Bosch Exxcel 1200 Express washing machine 6 620 Thu Mar 22, 2012 6:19 pm
Bosch Exxcel 1200 Express Washing Machine F18 Problem 19 27560 Sat May 08, 2010 5:01 pm
DIYnot
