combi boiler works for hot water but not central heating
9 Mar 2008
London
edit: water pressure ok now
moved into an old house; the combi has not been used for a while, its a Vaillant no. VCW-GB-242-EH and the hot water works ok but the central heating does not.. any ideas? The water pressure was on zero but i have brought the bar up to above the red marker- that keeps dropping tho, and i have to keep doing it..
Any ideas? my GF is getting the hump!
water leak somewhere, possibly from PRV, check discharge pipe outside.
does heating work when you've upped the pressure
Cheers for answering- no, cannot see a leak at this time(to be honest i only started on it today) but CH does not come on with 2 bar pressure
Outside discharge very very slight leak but i dont think this is the prob
There seems to be a problem with this site as its allowing you to register without saying where you are located.
Or perhaps the owner has modified the site to make the location unnecessary.
Thats a retrograde step because for many postings it helps us to give a better answer if we know where they are located.
Tony
Yes it is a side affect of the new setup, it isn't a permanent thing, just something that needed to happen during the conversion to the new s/w. The posters who are currently showing up as no location do have a location, so it will return soon.
Ok, I have constant water pressure! a valve was leaking on the outlet- its now reading 2 bar- still no central heating tho
wondering if a valve is closed or something-previous owners say it was working ok
