DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Raising a stone shower tray
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Redhotferrari
from United Kingdom
Thanked: 28 times
PostPosted: Mon Mar 17, 2008 5:39 pm Reply with quote
Hi Guys,
Looking for some advice on the best way to build a platform to raise a stone shower tray, its approx 900 x 900mm and is damn heavy!!!
Complicated to explain but due to the location of the waste, I really need to connect to it, however this will mean raising the tray by a good 6 inches!
Assume wood will be the best way, but what type? Way of fixing securely to floorboards? etc; etc......
Look forward to some helpful advice
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1243 times
PostPosted: Mon Mar 17, 2008 5:50 pm Reply with quote
build your self a 6 x 2 wooden plinth with 18mm ply on top.
mark and cut out access for the trap.
Back to top
 Alert Moderators
Redhotferrari
from United Kingdom
Thanked: 28 times
PostPosted: Sun Mar 30, 2008 10:52 am Reply with quote
Any more thoughts on this one guys?
If I build a plinth out of 6 x 2 do I need to fix this to the floor boards or will the weight of the tray and would be enough to hold it all in place?
Many thanks
Back to top
 Alert Moderators
keego
from United Kingdom
Thanked: 116 times
PostPosted: Sun Mar 30, 2008 11:53 am Reply with quote
Another option is to use 100mm thermolite block set on a bed of sand/cement & then bed the tray on to that with the same mix, tap it down till it's at the right hight & level then leave to set.
Back to top
 Alert Moderators
petetheleak
from United Kingdom
Thanked: 1 time
PostPosted: Sun Mar 30, 2008 11:55 am Reply with quote
Would fix to floor lessen any movement and remember to bed the tray down on a weak mix sand cement.
Back to top
 Alert Moderators
Redhotferrari
from United Kingdom
Thanked: 28 times
PostPosted: Sun Mar 30, 2008 12:19 pm Reply with quote
Forgiv my lack of knowledge, but whats a thermalite block? Is it like a breeze block? Are you saying to use half a dozen of these around the edges and middle of the tray and use the ply on the tray? Do I need to fix the ply to the tray in any way?was thinking something like gripfill!!
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1243 times
PostPosted: Sun Mar 30, 2008 12:25 pm Reply with quote
use what the mi say or your not covered for any guarentees.
how would you fix your plinth on bottom of tray to the breeze blocks.
Back to top
 Alert Moderators
Redhotferrari
from United Kingdom
Thanked: 28 times
PostPosted: Sun Mar 30, 2008 12:47 pm Reply with quote
Seco, your original reply to this was to build a 6 x 2 plinth, just trying to work out exactly what you mean by this, do you mean just build a frame out of 6 x 2 then fix the ply to it with a cut out for the trap, then just put the tray on top of this? Is it best to screw the frame to the floor boards as well?
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1243 times
PostPosted: Sun Mar 30, 2008 1:10 pm Reply with quote
get 4 x 6x2 spaced at 300mm centres approx then use noggins to join to gether gives you your base.
place 18mm ply on top and mark waste hole remove tray drill waste hole. but drill oversize as you don't screw waste to ply only tray.
use what mi say to secure tray to ply sand/cement, silicone, floor tiles adhesive etc.
and make sure you silicone the tray edges against the wall before placing tray in place.
decide what your using as a plinth first as you need to make you 6x2 the right length.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Sun Mar 30, 2008 2:39 pm Reply with quote
Seco.
Would you like to put your post in the FAQs as it comes up a lot. icon_question.gif icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Shower tray raising kits-do they work? 2 100 Mon Sep 01, 2014 9:25 am
Raising a Shower Tray 5 920 Wed Jun 15, 2005 3:18 pm
Raising the CW cistern for a better shower usage. 3 280 Sat Dec 12, 2009 11:38 am
Higher Watt Electric Shower vs. Raising Cold Water Cistern 8 100 Sat Jan 28, 2012 11:26 am
raising the shower head 7 700 Mon Dec 15, 2008 6:42 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
