path problem
12 Jun 2007
Essex
I am thinking of laying a path up to my front door using block paving.There is a slight fall towards the house ,about 40mm over 7 metres,is this a problem?Also can I use a decking board on its edge set in concrete,for the restraining edge,or will it need something more stronger.
don't use a timber edging as it will rot over time.
we tend to lay a path in screed sand mixed with cement as this alleviates the need for a compactor.
why, i hear you say?
a small narrow area such as a path can react in a non-uniform manner, when passed over by a compactor. spread can be a problem and dips can occur, causing a little ponding.
if you do lay the pathway in a 'screed mortar' as opposed to a standard bed of screed sand, then you will be able to haunch the mortar up the sides of the paviors creating a concrete restraint.
if the soil either side of the pathway is a fair bit higher than the path, then you will need to use a raised edging.
40mm fall in 7m is not a lot. lay the starter edge of the path to a line. this way you will have an accurate fall to the path.
Thanks for that noseall,that makes a lot of sense,what ratio for the screed would you suggest 5:1 ok?
just make sure the levels either side of the path will not cause rain water to flow onto the path and onwards.
a friend laid a block patio with a very small fall to the house which in itself was not a problem but the water from the garden surrounding the patio flowed nicely onto the patio ........
