Celotex GA3000 and Kingspan T10 / TW55 the difference?
22 Oct 2004
Is there any real difference between Celotex Tuff-R GA3000 rigid boards and those by Kingspan such as T10 / TW55?
My local merchants sell the Kingspan range which is much cheaper then any Celotex GA3000 I've seen online. We intend to mechanically fix them to a solid brick wall (internal).
Pars.
But are they the same kind of product? because the best price I've got is for the Kingspan board at £12 per board (ex VAT / free delivery)
Pars
Given all other physical properties (e.g. foam, mineral wool, etc.) being comparable, the thermal property you should compare is the K value. (measured in W/m.K)
Celotex GA3000 has a K value of 0.023 W/m.K
Kingspan rigid phenolic has a K value of 0.021 W/m.K
Kingspan rigid urethane has a K value of 0.023 W/m.K
So they are all about the same with Kingspan phenolic being fractionally better.
For comparison, the average mineral wool quilt has a K value about 0.040 W/m.K - which is why 200mm mineral wool is about the same thermal value as 100mm foam.
