heating controls
31 Oct 2006
Lancashire
could any one please show me are do me a diagram on how to wire a single channel programer, a wireless room stat with a reciever a frost stat , pipe stat then to the boiler i know how to wire the progammer then the reciever then to the boiler but not sure how to work the frost stat and pipe stat how you can help
All frost stats should be wired in series with the pipe stat. This is to make sure that although the air temp may drop to near freezing, the boiler won't fire unless the water temp in the pipes gets below 10C, usually.
Stops the boiler firing all night in the winter ;)
Pipe stat should always be fitted to the heating return and pipes still insulated appropriately though.
