Baxi combi question
14 Jul 2005
Yorkshire
Just taking precautions here, so thought i'd ask for advise
Our combi is fitted in the bedroom airing cuboard and when little britain had it's little earth tremor not so long ago, It cracked and loosened some of the plaster board on the ceiling, directly above the combi boiler.
A few small chunks fell off the other day and by the looks of it have gone inside the combi, through the narrow gap on top of it.
Is this going to cause any upset ?
I will call someone out immediately if this could be dangerous.
I would assume that all parts must be sealed and airtight inside there.
Thanks for any help.
As with most boilers, its pretty well contained. However any debris that falls into the top, ideally should be cleaned out. It shouldn't cause any major problems, but if its resting against the combustion chamber, then it might smell.
