Double glazing wrong way round?????
30 Jan 2008
Essex
Hi guys,
I have recently had my consivertary double glazed as this was the only part of the house that hadnt been done.
The other nite I noticed that the 4 plastic clip on battons that hold the glazed units in place are on the outside where as the rest of the house has they are on the inside.
Surely a theif could easily remove these and gain access to the property?
I wanted to ask you guys before if this is right or not before I phone up the company that installed it,
Paul
On some installs I have seen the plastic bars/trims are fitted to the outside but the fitting of the rubber gasket on the inside makes them impossible to remove.
I would check with your installer to be sure.
There are internal and external glazed frames
If the frames are externally glazed, then a foam strip with adhesive strip prevents the glass unit being removed easily
