rad valves
17 Feb 2008
Berkshire
when you screw them on to rad, how do you know where to start screwing so it ends up facing the correct way facing the pipes coming from wall.
When you wrap the ptfe tape round it, you will be able to screw it on & stop where you like. THe tape will give enough to add about 3/4 of a turn after it is tight. Try not to undo it though.
May not be the allen key type either , but i am not a plumber either. I am a servivce engineer (gas) in case onetap is looking :wink:
