DIYnot
Local | Network
   DIYnot > Forums
Local | Network
boiler pumping but not igniting
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
jos
from United Kingdom
PostPosted: Mon Sep 06, 2004 5:29 pm Reply with quote
my IDEAL classic nf fanned flue gas boiler is not igniting.When the water is switched on the pump and fan appear to be working and the boiler sounds as if it wants to ignite. There is no sound when cental heating is switched on,that is there is no pilot light or any sign of life. Help me diagnose the problem before i am totally ripped off by a plumber.
Back to top
 Alert Moderators
ArtfulBodger
Thanked: 1 time
PostPosted: Mon Sep 06, 2004 5:48 pm Reply with quote
I'm not 100% sure that the people who can help you will appreciate this remark! icon_biggrin.gif
Back to top
 Alert Moderators
jos
from United Kingdom
PostPosted: Mon Sep 06, 2004 6:29 pm Reply with quote
sorry if i have offended the good honest workers,but the media/tv folks are always warning us of rogue tradespeople. I would be interested in finding out how much i should be paying as i do not intend to deal with the problem myself
Back to top
 Alert Moderators
PEDANTICVINDICTIVEMAN
from Western Sahara
Thanked: 1220 times
PostPosted: Mon Sep 06, 2004 7:40 pm Reply with quote
About time the sodding media did customers from hell on tv, last time some old misery asked me in a nasty tone how much I was going to charge for repairing his toilet I said nothing as you can get someone else now, bloody condeming me before I even got in the door, got back in my van and went THEY MIGHT rip you off where as I wasn't going to, too late now bye bye.
Back to top
 Alert Moderators
from Western Sahara
Thanked: 1220 times
PostPosted: Mon Sep 06, 2004 7:46 pm Reply with quote
Yes well I think your boiler sounds old and you wont get the spares, I can powerflush your system for 850.00 then sub out the job of fitting you a new combi you dont want for 5500.00 but you will get a free rad valve and a certificate from CORGI to tell you it's new and shiny, better still go down the pub and find some bloke who's had ten pints who "does a bit", he will be bound to be cheap enough for you.
Back to top
 Alert Moderators
jos
from United Kingdom
PostPosted: Mon Sep 06, 2004 8:12 pm Reply with quote
forget i even asked.You obviously are not going to bother answering my problem.Terribly sorry I even bothered asking. I really did not expect this kind of response.I assure you I am not a customer from hell.I never question the workmen that come to my house. I do not quibble about the price. It would have made it easier for me to explain the problem to whoever i was going to employ. I'll just go ahead and contact someone fom the yellow pages.I really do not feel That I should have to grovel to get simple advice.
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Mon Sep 06, 2004 8:29 pm Reply with quote
you could try to reset the boiler overheat stat if it was fitted with one...it's the red button on the side of the boiler control box.....are you sure that your room thermostat is calling for heat in CH mode?
Back to top
 Alert Moderators
jos
from United Kingdom
PostPosted: Mon Sep 06, 2004 8:41 pm Reply with quote
Thank you ollski for your advice. My thermostat is set at a high temp so that it is calling for heat in CH mode.I set it as such to check if the pilot light would come on.There is a overheat stat control of some kind it appears to be a red screw. i would not know how to reset it.
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Mon Sep 06, 2004 8:55 pm Reply with quote
it should just be a button to press....have you just switched your heating on for the first time?...it sounds like two different problems the heating probably down to you motorized valve not making a contact and the lack of ignition either down to the boiler overheat stat or possibly the air pressure switch.
Back to top
 Alert Moderators
from Western Sahara
Thanked: 1220 times
PostPosted: Mon Sep 06, 2004 8:56 pm Reply with quote
Bye Bye forgotten allready.
Back to top
 Alert Moderators
jos
from United Kingdom
PostPosted: Mon Sep 06, 2004 9:07 pm Reply with quote
the heating has been kept on at a very low thermostat setting throughout the summer.I only raised the temperature setting to check if the ignition would work.What is the air pressure switch?The problem only occurred this morning. The boiler is approx 9 years old.
Back to top
 Alert Moderators
ArtfulBodger
Thanked: 1 time
PostPosted: Tue Sep 07, 2004 6:00 am Reply with quote
The boiler starts in a pre-determined sequence when heat is called for. The fan starts, the pressure switch operates if the pressure is sufficient, the starter starts, the pilot valve opens, when a flame is established the main gas valve opens.
You should get someone with the necessary test gear to check it out.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Pumping water with strange noise and boiler cut outs 5 60 Fri Aug 31, 2012 10:19 am
Boiler Cycling and Pumping Over 14 1300 Sat Dec 12, 2009 8:25 pm
Boiler is still pumping over 43 4640 Mon Sep 17, 2007 10:30 am
Ideal E type boiler connections and pumping over 2 60 Sat Jun 01, 2013 2:18 pm
Whooshing in airing cupboard/boiler pumping over 8 360 Sun Jun 12, 2011 12:59 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
