DIYnot
Local | Network
   DIYnot > Forums
Local | Network
showers and rcds
Author Message
chelsea83
from United Kingdom
PostPosted: Wed Apr 02, 2008 9:12 pm Reply with quote
hello need to inquire about showers. are you supposed to have a rcd when installing an electric shower or is the 40A mcb suffisent protection in the event of a fault?
Back to top
 Alert Moderators
streetlighter
from United Kingdom
Thanked: 38 times
PostPosted: Wed Apr 02, 2008 9:19 pm Reply with quote
Under the 16th edition an RCD is not required but recommeded due to electricity near water. But in the new 17th all circuits in a bathroom must be protected by one or more RCD/RCBOs.
Myself i would not install a shower without a 30mA RCD in the circuit.
Back to top
 Alert Moderators
electrospark
from United Kingdom
PostPosted: Wed Apr 02, 2008 9:21 pm Reply with quote
As far as i am aware and i know i will be corrected if wrong... but under the 16th edition there is no requirement to install on a RCD. Although it is good practice to install them on one. (As I do)
Back to top
 Alert Moderators
electrospark
from United Kingdom
Back to top
 Alert Moderators
chelsea83
from United Kingdom
what if there wasn't enough room in the dist board to fit an rcd would it be a major issue?
Back to top
 Alert Moderators
electrospark
from United Kingdom
PostPosted: Wed Apr 02, 2008 9:23 pm Reply with quote
Its up to u as there is no regs to suggest to. But I would use one...
Back to top
 Alert Moderators
electrospark
from United Kingdom
PostPosted: Wed Apr 02, 2008 9:24 pm Reply with quote
Can u fit an RCBO what board do u have?
Back to top
 Alert Moderators
chelsea83
from United Kingdom
PostPosted: Wed Apr 02, 2008 9:26 pm Reply with quote
theres just enough room to fit the new 40A mcb. its a crabtree sb6000
Back to top
 Alert Moderators
streetlighter
from United Kingdom
Thanked: 38 times
PostPosted: Wed Apr 02, 2008 9:28 pm Reply with quote
Do crabtree still supply BS3871 sb6000 MCBs for those units ? Mind i suppose the fuse company would have them.
Back to top
 Alert Moderators
daytona
from United Kingdom
PostPosted: Wed Apr 02, 2008 9:32 pm Reply with quote
as said before,you dont need rcd protection for the shower if the install is under the 16th edition.bs7671 is only a minimum standard though.you wont get a spark to say not to use an rcd with this in mind.
its up to you(or your spark)but i wouldnt.
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 163 times
PostPosted: Wed Apr 02, 2008 9:33 pm Reply with quote
External RCD in an enclosure?
It's normally manufacturers recommendation to fit an RCD to a shower circuit (16th) and not that of the wiring regulations.
Back to top
 Alert Moderators
electrospark
from United Kingdom
No idea, they may do..
Can you fit a small 2 way board to the side with RCD. More work but worth it. Its up to you. I would, but like we said there isn't any requirement. So do it before july if u don't want to fit one..
Back to top
 Alert Moderators
chelsea83
from United Kingdom
PostPosted: Wed Apr 02, 2008 9:44 pm Reply with quote
thanks for the info, might try the separate enclosure with rcd
cheers
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Showers, RCDs, MCBs and Fuses 30 1360 Sat Jun 14, 2008 5:40 pm
Time Delay RCDs and 17th Edition 7 800 Tue Feb 05, 2008 1:16 am
Split load with two RCDs 19 1640 Sun Jan 13, 2008 8:54 pm
TT supply sytem RCDs 5 440 Thu Oct 04, 2007 9:42 am
RCDs - Should they trip without MCB 10 980 Tue Aug 21, 2007 4:15 pm
DIYnot
