cold water tanks
5 Apr 2008
Birmingham
:rolleyes:
am trying to boost my hot & cold water supplies to a new ensuite bathroom and have bought pump that looks like it could boost water to the moon, certainly cost enough,however problem is I can't fit it straight off the main CWS, but I have no cold water tank, only one that feeds the gas central heating header tank and the immersion heater which is also a heat exchanger for the central heating.
It looks like every cold water tap in my house comes straight off the mains
Any suggestions ???
Cheers fast answer
yes I can do that, thing is cold water pressure is also abit naff, takes about half an hour to fill the bath, what would happen if I did fit the pump to the mains supply ??
the water supplier would go spare :eek: :eek: its illegal
take a tapping off the header tank to the pump and from the cylinder to the pump and feed the bathroom h+c via the pump assuming twin impeller
if the tank is big enough :idea: :confused:
Thanks Kev,,did think there would be regs someone, the installation booklet with the pump kept putting in big red letters do not fit to mains !!!!
will give your suggestion a go, the tank looks fairly big its about 23"x 20"x20" but how many gallons it holds???
think I need to put this project in the DIY disaster page :cry:
