Guest
Thanked: 0 times
Posted: Wed Dec 04, 2002 12:03 pm Post Subject: Removing a fence post |
Can you please advise the best way to remove a fence post embedded in concrete. This broke recently in the storms and I now have 18 inches remains, 6 inches below the surface of the concrete.
Any suitable advice would be appreciated.
Many thanks. |
Guest
Thanked: 0 times
Posted: Wed Dec 04, 2002 12:30 pm Post Subject: Re: Removing a fence post |
best way to do this is to dig around concrete and remove the whole lot post & concrete together, if you can,t you will have to hire a concrete breaker |
DAZB
Joined: 10 Sep 2002 Posts: 765 Location: United Kingdom Thanked: 0 times
Posted: Fri Dec 06, 2002 12:11 am Post Subject: Re: Removing a fence post |
Assuming you want to retain the concrete in order to slot another post in , then the easiest way to remove the broken remains is to get the widest Auger drill bit you can and drill holes down the centre of the remains in order to remove as much material as possible then you should be able to prise the post from the sides of the concrete thus splitting it and allowing easy removal. |
cc_7up
Joined: 03 Apr 2007 Posts: 1 Location: Leicestershire, United Kingdom Thanked: 0 times
Posted: Tue Apr 03, 2007 8:45 am Post Subject: Fence post socket? |
_________________________
Lynda, moderator
please see forum rule 20
the post you hi-jacked is nearly 5 years old |
