Frosted / obscure glass - which way around?
3 Sep 2006
West Mids
Which way around should obscure glass be when made up into a DG unit and when installed?
The patterned side should face the inside of the DG unit, and the patterned glass should be on the inside of the building. I assume this is so the pattern doesn't attract dirt, and to make the glass easier to clean by facing a flat glass face to the outside (the patterned glass may have slight indentations on the unpatterned side).
I've just installed one at home - a standard one form a merchant, with no need to de-glaze to fit, and the rough pattern is facing inside the house
I can't think of any issues except as mentioned, being a bit harder to wipe clean.
