| Author |
Message |
nozspark
Joined: 24 Aug 2006 Posts: 1062 Location: Flintshire, United Kingdom Thanked: 34 times
Posted: Thu Apr 10, 2008 9:13 pm |
Got to repair a storage heater for someone (replace 2 elements and a thermal link) and they want me to service the others.
Apart from a quick vac, checking the elements, link & operation of the dampers what else is involved??  |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
breezer
Joined: 03 Jan 2003 Posts: 23330 Location: Sussex, United Kingdom Thanked: 24 times
Posted: Thu Apr 10, 2008 9:14 pm |
regret for taking on the job |
| Back to top |
nozspark
Posted: Thu Apr 10, 2008 9:21 pm |
No regret at this present time, got to change the CU for the heaters aswell as it has suffered some overheating!!!
Tomorrow might be a different matter though.... |
| Back to top |
breezer
Posted: Thu Apr 10, 2008 9:22 pm |
good luck (with the heaters) |
| Back to top |
nozspark
| Back to top |
RF Lighting
Joined: 31 Mar 2006 Posts: 16139 Location: Leeds, United Kingdom Thanked: 718 times
Posted: Fri Apr 11, 2008 3:47 pm |
possibly a bit late now, but are you aware that some older storage heaters will be lined with asbestos? |
| Back to top |
Cremeegg
Joined: 16 Apr 2007 Posts: 527 Location: United Kingdom Thanked: 6 times
Posted: Fri Apr 11, 2008 8:25 pm |
Thermal cutouts can often trip - quick and easy to reset. Thermostats up to around £50. Anything that can go brittle with heat will have done so long ago - as soon as you touch it it's likely to fall apart. Any problems with spares try www.storageheater.co.uk - great service.
Most rads prior to 1985 will have some asbestos in them - your local Env Health Dept may be able to help with which models and subsequent disposal. My local licensed asbestos removal company charges £500plus to remove an old asbestos storage heater. |
| Back to top |
SeanT
Joined: 15 Jul 2007 Posts: 324 Location: West Midlands, United Kingdom
Posted: Fri Apr 11, 2008 8:50 pm |
Every local authority provided recycling centre now has to provide an asbestos disposal facility - for free (to local householders) - in england at least - so get the householder (or you in a car rather than a van) to take said asbestos down the tip - just don't cut, drill or drop the stuff... |
| Back to top |
RF Lighting
| Back to top |
SeanT
Posted: Fri Apr 11, 2008 9:08 pm |
| Back to top |
RF Lighting
Posted: Fri Apr 11, 2008 9:28 pm |
Have you ever tried to move a storage heater while it is still full of cast iron bricks? |
| Back to top |
SeanT
Posted: Sat Apr 12, 2008 6:26 am |
They are quite heavy, but I have moved a couple, yes. |
| Back to top |
nozspark
Posted: Sat Apr 12, 2008 3:22 pm |
All done now!
Heaters were Creda and < 15 years old.
Tested all elements out, ensured stats & dampers operating & gave them a good clean, managed to do that without unloading the bricks (front & top covers off) - only found one other thermal link replaced with a piece of wire, will replace that next week!!
Thanks for your help, will check out that site for parts! |
| Back to top |
