non finned radiators modern equivilent
12 Jul 2004
Surrey
i have 3 radiators i want to change 2 to modern equivilents of simmilar output and the third i am hoping for around 30 to 40% extra output as the bathroom takes ages to warm as its all outside surfaces
bathroom radiator is 740x1270 what size modern double finned radiator would give around 1/3 more output!!!
the other 2 are 2x8ft and 2x7ft3" what modern double finned radiator sizes would be equivilent please !!!
could you please give me the approximate output of my present radiators to help with other calculations please they are all non finned thanks
look up stellrad or myson online, they will list what sizes are available and the styles.
If you want a bit more heat than your single panel go for a P+ which is twin panel and single convector.
thank you superdupergasman for your answer :D
what i am realy after is finding out the capacity of the old rads so i can size the new ones as small as possible as the present rads all but fill the usable walls in my terrace house what would your best guess about comparative outputs be between plane finned and double finned!!!
i was assuming around 35 percent between plain and finned and 2.6 times capacity from plain to double finned do these assumptions seem reasonable or way out :roll:
The PTS catalogue is a good resource in situations like this, as it contains many pages of radiators from many different manufacturers along with all the stats, allowing you to compare heat outputs and sizes.
There were even one of two examples of non-finned radiators in there, allowing me to get a rough idea of the output of my old rads, none of which had fins.
You might be surprised just how much more heat a finned radiator will put out than a similarly-sized, non-finned equivalent !
To double check your estimates, put your figures into one or two of the radiator size calculators available online - they'll give you an idea of the heat output you should be aiming for.
