RCBOs for Older Type Wylex Board
28 Jul 2006
Oxfordshire
Need advice from you RCBO gurus.
Looked at a refurb today. The existing board is an older Wylex skeleton (DIN) board populated with old Type 2 (NB) type breakers.
There's a lot to do in the property that needs RCD protection and just replacing the board with a new one would cause major problems.
So I may as well make it a 17th and swop out all the old breakers for RCBOs (yes I know)...
Has anyone had any experience of shoehorning the new sytle NSBS RCBOs into the old style Wylex boards? Any issues?
iirc the old NN range boards have a completely different bussbar arrangement from the current boards.
Yes, the bus fits onto the front of the old style mcbs.
I guess I could just fit a new isolator and busbar - basically replace all of the guts of the consumer unit - or retain the incomer (I think that has the solid neutral bus attached to it) and provide a short link from incomer to a new busbar that serves all the RCBOs?
agree with that.
dont mullah the old board,just fit a new skeleton.
while your at it,remove that lethal metal shield attatched to the enclosure
and dont just bin the plastic one,see that so often.
