DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Boiler: Ideal Icos HE24 display off and no hot water no heat
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
JamesV
from United Kingdom
PostPosted: Sat Apr 19, 2008 6:18 pm Reply with quote
I have an Ideal ICOS HE24 condensing boiler (unvented system) and we have no hot water and no heat.
The central heating programing unit is on and controls the automatic valves. What is not working is the boiler itself. It is completely off. Usually there is a green light on and you can hear the spark. Today it is dead.
What should I do? Can I do something myself? Should I call someone? Who?
Thanks for your help!
Back to top
 Alert Moderators
LUNAT
from United Kingdom
Thanked: 22 times
PostPosted: Sat Apr 19, 2008 6:37 pm Reply with quote
HI
carry out simple checks
check/replace fuse
make sure all external controls are calling for heat/hot water
Back to top
 Alert Moderators
JamesV
from United Kingdom
PostPosted: Sat Apr 19, 2008 6:43 pm Reply with quote
I think that all controls are OK. Fuse seems to be OK. When I remove it the main display turns off and when fuse is inserted, display with CH/HW turns on.
The problem is that there is no pilot light on the boiler unit...
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 795 times
PostPosted: Sat Apr 19, 2008 8:39 pm Reply with quote
Thats because it doesn't have a pilot light. It's electronic ignition.
If the display is dead, although you seem to contradict your self on this, then it will be the pcb blown.
Back to top
 Alert Moderators
JamesV
from United Kingdom
PostPosted: Sat Apr 19, 2008 8:52 pm Reply with quote
Sorry that the display issue was not clear. There are 2 displays:
1) the display on the boiler unit and this is dead
2) the display for the central heating i.e. where you can select the timer for the central heating/hot water etc. and this one is OK
So I guess the PCB is dead icon_sad.gif Do you know what I should do next? Tried to call British Gas and nobody is available right now...only Monday or Tuesday.
Back to top
 Alert Moderators
superdupergasman
from United Kingdom
PostPosted: Sat Apr 19, 2008 9:51 pm Reply with quote
Does the boiler work?? its fine to run it without the display!!!
Back to top
 Alert Moderators
JamesV
from United Kingdom
PostPosted: Sun Apr 20, 2008 8:37 am Reply with quote
There is no sign of life in the boiler at all.
I think that the power supply to the boiler is OK because it is the same source as the central heating "timer" unit. The water pressure to the boiler is also OK: around 1.5bar so something is wrong inside the boiler.
I opened it up yesterday to check is there was a fuse or something but could not see anything suspicious. Everything was dry etc.
There was a big black box containing the PCB and a warning sign indicated that the part was not servicable.
Do you know if I can buy the PCB somewhere? What do you recommend?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 795 times
PostPosted: Sun Apr 20, 2008 1:08 pm Reply with quote
Call Ideal in on fixed price call, 210. All parts included. It will cost you about another 100 on top if a local chap fixes it.
Back to top
 Alert Moderators
diverdee
from United Kingdom
Thanked: 2 times
PostPosted: Sun Apr 20, 2008 4:24 pm Reply with quote
before u change the pcb do 2 simple checks.first it has been known for the mains plug to vibrate loose on this xxxx sorry ideal boiler make sure it fully pushed in .second there is a small fuse on the pcb check it with a continuity tester it is a little black peg sticking out of the pcb. and of course make sure u isolate the boiler before doing this
Back to top
 Alert Moderators
gasandoilman
from United Kingdom
Thanked: 5 times
PostPosted: Sun Apr 20, 2008 5:55 pm Reply with quote
and check the 2amp fast blowing fuse on pcb?
Have you 240v at boiler/pcb?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1100 times
PostPosted: Sun Apr 20, 2008 6:02 pm Reply with quote
No hot water?
Doesn't your hot water cylinder have a backup electric immersion heater? Look for a thick cable coming off it going to a wall plate with a switch....
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 795 times
PostPosted: Sun Apr 20, 2008 6:03 pm Reply with quote
Back to top
 Alert Moderators
JamesV
from United Kingdom
PostPosted: Sun Apr 20, 2008 7:04 pm Reply with quote
Thank you all for your help.
There was indeed a switch for back-up electric heater in the boiler which means we have hot water.
I have called a plumber so let's see what he finds...I will let you know if it was the PCB or something else.
Back to top
 Alert Moderators
superdupergasman
from United Kingdom
PostPosted: Sun Apr 20, 2008 8:08 pm Reply with quote
BG will do a fixed priced repair for 170.....safer bet than calling a plumber.
Back to top
 Alert Moderators
JamesV
from United Kingdom
PostPosted: Mon Apr 21, 2008 12:27 pm Reply with quote
A local company has started the job. Conclusion is that PCB needs to be replaced and it will now cost me at least 340 quid!
Is the "fixed price" repair you mention by BG really fixed price? I.e. if the repair cost would have been 30 quid or 500 quid, they still charge the same?
If this is correct then I should really have gone with BG but now it's too late icon_sad.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Ideal Icos HE24 not coming on doing nothing 0 on display 4 620 Mon May 03, 2010 7:32 pm
Help!! Ideal Isar HE24 working but display dead 6 100 Sun Aug 04, 2013 6:57 pm
ideal icos boiler - high pitch noise no display/burner light 3 900 Sat Feb 27, 2010 1:07 am
Ideal system icos--no display on user control 12 1660 Wed Aug 23, 2006 7:34 pm
Ideal Icos NO Display.... HELP 12 340 Wed Dec 08, 2010 7:08 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
