DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ultracom 38 CXi
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
BigBurner
from United Kingdom
Thanked: 2 times
PostPosted: Sun Apr 20, 2008 12:27 am Reply with quote
I read on the Glow Worm site that the Ultracom 38 CXi can have an outside sensor. I think this means for outside weather compensation. The installation manual mentions little of this and does not show how to connect one. Does anyone know of this sensor? I also want a remote timer. May the boiler facia mounted timer be move to another room? What do people think of the Ultracom 38 CXi? It looks like a Vaillant inside and they own Glow Worm.
Thanks.
Back to top
 Alert Moderators
snb
from United Kingdom
Thanked: 247 times
PostPosted: Sun Apr 20, 2008 7:28 am Reply with quote
yes the outside sensor does vary the temp of the heating. connection is only 1 cable. instructions are with the outside compensator
Back to top
 Alert Moderators
BigBurner
from United Kingdom
Thanked: 2 times
PostPosted: Sun Apr 20, 2008 9:25 am Reply with quote
Thanks. Does the sensor instructions tell you how to set up the weather compensation curve? or is this pre-set in the boiler? I have never come across a weather compensator that cannot have the curve set.
With a little more looking and downloading, I saw that a thermostat/programmer can be bought that matches the CXi control system and modulates the burner accordingly and it looks simple to fit. If it modulates the burner then this must be a "senor", not a switching stat, sending data to the boiler which it uses to then to calculate and modulate the burner.
I did a search on this forum on the CXi and problems on earlier model have had mods so it is now a sound boiler.
Any opinions on the CXI?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Sun Apr 20, 2008 1:06 pm Reply with quote
I fitted my first one this week. Several niggles that were worse than the Vaillant, but several things that seemed better, allowing for the fact I know the Vaillants inside out and don't the Glow Worm icon_rolleyes.gif
All in all I think it's ok for the price. I shall be specifying more as I can offer the customer a better deal on them.
Back to top
 Alert Moderators
cozzmic
from United Kingdom
Thanked: 58 times
PostPosted: Sun Apr 20, 2008 1:21 pm Reply with quote
Yep the Ultracom CXI's seem to be ok, have installed quite a few and had one which had a twisted o-ring in the divertor valve and another where the exp vessel was not charged but other than that they produce the goods.
Back to top
 Alert Moderators
BigBurner
from United Kingdom
Thanked: 2 times
PostPosted: Sun Apr 20, 2008 6:36 pm Reply with quote
Thanks. Is the CXi quiet? I am looking at the 38 kilowatt model.
It ticks a lot of boxes.
Back to top
 Alert Moderators
cozzmic
from United Kingdom
Thanked: 58 times
PostPosted: Sun Apr 20, 2008 6:58 pm Reply with quote
Yes they are pretty quite better that some and not others. I hav'nt done the 38 only the 30's but should be ok. On heating only it is whisper quite.
Back to top
 Alert Moderators
BigBurner
from United Kingdom
Thanked: 2 times
PostPosted: Sun Apr 20, 2008 11:14 pm Reply with quote
This is to go in the loft. Never done a loft combi before. I believe it needs: a light, boarding and a shoot down ladder. Anything else?
I fitted a HXi about 3 years ago. I see the Ultracom appears to be this range with just the Ultracom word used. Is that so?
The vented Ultracom can have an Climapro Programmable Room stat fitted by having another (extra?) board fitted. The Climapro Programmable Room stat modulates the burner. I wonder if that can also be the case with the older HXIs?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
what wireless thermostat for my glowworm ultracom cxi30 2 40 Tue Jun 05, 2012 10:46 am
glow-worm ultracom 38cxi DHW hot-cold-hot-cold problem. 7 120 Mon Mar 19, 2012 8:33 pm
Glowworm Ultracom 30cxi boiler - Low water pressure 4 660 Thu Feb 16, 2012 3:10 pm
Ultracom 24 2 40 Mon Jun 25, 2012 4:52 pm
Glow Worm Ultracom 38cxi Canoe Filter Location 5 80 Fri Aug 10, 2012 8:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
