Mixing Ariel Cables?
23 Feb 2006
Southampton
The issue I have is that the Hi Fi signal in my lounge is not very good, I have got ot connected to a 2 outlet patrease TV + FM. My question is: Can you run the FM signal down the same cable as the TV?
I currently only have one cable going to the outlet.
I do have a FM Ariel and TV Ariel on my roof, I could run the signals via a Y type splitter?
Your thoughts
Phill
The wall plate is likely a diplexer - Accepting both FM and UHF on the same aerial coax. However, you do need to fix the FM and UHF before sending it down the coax. To do this, use a diplexor in reverse.
Item A88945 is what you need to combine - HERE
Most 'tv' boosters in lofts also have an FM input.
If someone's gone to the trouble of the plate and the two aerials i'd check if there is a masthead splitter first.
From the link in the previous post you'll see a greeen box, you should somewhere have something like that with one cable going in (from the aerial points) with two cables coming out, one to FM one to TV aerial, it'll be either in the loft or by one of the aerials.
