My Chaffoteaux Britony 80 Combi has developed a fault - The DHW seems to be running ok - but when the tap is turned off the boiler carries on running - thus not switching back to CH. I have found that if I turn the tap on and off (about 30 times sometimes) the boiler will then stop and switch over to CH. While in DHW mode with the tap off it does stop firing but something still running, then about a minute later it will fire for 10 seconds (keeps going on like this ) ?? Im hoping its not the 3 way valve as this was only fitted just over a year ago!!. Any ideas gratefully received. Thanks in advance.
