radiator in conservatory
9 Jun 2007
Manchester
just been asked to quote for a rad in a conservatory ( new build), my only concern is,,,,
is there some reason why all the conservatories i see have electric wall heaters...
probabley cause they can't fit a zone valve to it and a seperate wall stat
Heating for a conservatory must be controlled totally independently of the other source of heting in a property, hence the electric heaters.
Other options would be to have an indepent room stat and zone valve, creating a seperatly controlled zone for the conservatory.
HI
reasons for not having RADS in the cons..
1.difficult to run the pipes
2.having to turn full system just to heat a rad in the cons..
3.ugly sights of the pipework
i put a rad in one a few weeks ago and was alot bigger job than i first thought.
main problem was gettin pipes through wall into it as customer had woodflooring. they were surface aswell(wouldnt want that in my house)
i wouldnt see a problem if you can get under floors.
thats why you can't see a problem then.
if you zoned it you'll have to run all the pipework back etc.
I normally suggest a wall hung Smiths fan convector. We bring F+R through the 1st floor void to adjacent the heater.
As the heater has its own controls it can be said that it is separate.
We are doing a job at the moment were we are converting two to radio control as part of a whole house BMS.
i had not heard of having to zone a rad in a conservatory.....only 2 yrs ago had bc round re mine and he said aslong as trv'd then ok ?
how does one keep up, when ur a 1 band man, with no head office to keep u informed of all the changes !!
Trade press, not gas installer, as this appears to have little to do with domestic gas these days :rolleyes:
Forums such as this, or join THESE
