Usually a hole in the outer sheath of the heating element, allowing it to short circuit to earth. Modern dishwashers are not easy to work on so you may be best getting someone in to fix it.
the heater is in the base of mc tip it on the side undo the six screws ,the heater is a tube a bit smaller than a coke can , unplug the 2 wires on it and turn on if it dont trip thats your problem heater is about 35 quid or you can megger it if you have a meter
Thanks for the advice. We opened it up today and found heavy corrosion on the main motor, we believe the motor has seized. Water had leaked in because the main feed hose had leaked. We tried drying it out and trying it again but with no luck.
Do you know how much a new motor is likely to cost? and is it a viable repair?
Thank you in advance for any advice anyone can give.
Retail price of the motor is about £109. If the appliance is less than 5 years old it would be cheaper to get Hotpoint to come and do the repair as there is a 5 year parts warranty.
