DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Whistling Annoyance
This topic originated from the How to page called Double glazing
Click here to return to the page called Double glazing.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
crealy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 14, 2004 12:01 pm    Post Subject:
Whistling Annoyance
Reply with quote Thanks
Ive just moved into a new house where the Double Glazing was installed some 6 years ago but i do not know who installed it. When the wind whips down the street, it causes my windows to let out a shrill whistle. This is occurring in both of my windows in the bedroom , therefore causing an awful annoyance and lack of sleep. Does anyone have any ideas as to why this is happening. Im guessing that its to do with the seals but they all look ok to me? If you apply pressure to the window it will temporarily stop...until you take the pressue off!! Doe it need a complete new re-installation of the windows?? icon_twisted.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Sep 14, 2004 12:18 pm    Post Subject:
Re: Whistling Annoyance
Where about on the window and is it on the frame or the glass unit ?
Back to top
 Alert Moderators
crealy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 14, 2004 1:05 pm    Post Subject:
Well theres a good question - Ive applied pressure on both the window(just pushing the centre of the glass) and also around the frame which also seems to do the job. On one of the windows, it seems to stop if you open the top window up(which i did last night @4am!!!) Ive just been to B&Q to purchase some rubber draft excluder which Im thinking I will apply to the top window around the inside of the frame so as to see if its the top window not shutting correctly??? To be honest, im at a bit of a loss - its too coincidental for both windows to be whistling isnt it???
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Sep 14, 2004 2:57 pm    Post Subject:
Before you do anything, double glazing normally comes with a 10 yrs warranty.
Can you trace back the last owner or the house deeds may help.
If you look carefully there should be a date stamped on the inside spacer bar between the 2 glass unit when the windows was made.
A photo would be helpful to see what type of window seal you have. Sounds like you have the wrong size seal which is well known.
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 24 times
PostPosted: Tue Sep 14, 2004 3:42 pm    Post Subject:
my temporary solution[10 years ago] that i had forgot about
take some lightweight foam draught excluder[realy cheap thin one]
cut down the middle [you now have two sticky halves]
lift up rubber seal clean and stick behind push back
it will push it forward to close the gap and you should,nt
be able to see the foam
you may also have to lighly lubricate the seal on the hinge edge
if it grips to much
big all
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
crealy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 16, 2004 10:39 am    Post Subject:
Thanks for your replies so far guys. Im prob being totally thick here:
Ive checked the unit for a date stamp but couldnt find one. The seller of the property has moved abroad so not able to get in contact to find out who installed it.....nightmare!
When it comes to fitting the draught excluder(and this is where im being thick!!) , am i pushing back the rubber seal that comes out of the frame on the inside and pushes against the sealed glass unit? The reason i ask is because the rubber seal isnt that wide. My next question would be Do I have to take out the plastic beading and insert under the seal that way, then reinsert the plastic beading on top??
I apologise for my lack of brain but I have little or no knowledge of double glazing. icon_confused.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
whistling noise through windows 2 1980 Wed Jan 31, 2007 6:04 pm
Whistling windows 2 1020 Mon Jan 15, 2007 10:09 pm
'whistling' front door 2 520 Mon Jan 10, 2005 1:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
