Mornin all
Recently viewed a property for sale, approx early 1900's Victorian Semi, a big 5 bed place on 3 floors, has had a recent loft conversion + a general refurb (all done from Sept 07 to April). Couple of red flags came up in the inital viewing that i would appreciate some advice on pls:
- Visible damp above an external wall window, the window is in a bedroom on the first floor. Have been told that a chimney brest was removed from that wall during the refurb + that damp got into the exposed area over the winter + is now drying out. Not sure if that's a plausible explination, also upon consideration the external photo's + neighbours place don't show that a chimney would have been in that location.
- Had a partition wall removed between the Kitchen + Dining Area, now open plan. Therefore a Steel Beam has been brought in, but there are 1 or 2 cracks (not minor plasterboard cracks) adjacent to the new beam + also on the roof of the partition wall above the beam (on the 1st floor). The sellers say the builder didn't initially prop the upper wall enough...........hence the cracks. But they say it's cosmetic + is structurally sound. You can see where they have attempted to fill it...........To my knowledge this is a standard procedure - u alco prop a partition + insert the beam with sufficeint end bearing as per struc engineers recommendation + get your bldg control approvals etc etc.
The building control approval should hopefully cover not only the loft conversion but also the new beam, so i will check the docs on the 2nd visit. But I'm dissapointed with there expilinations..........or am ijust being paranoid?
Any advice most appreciated
