DIYnot
Local | Network
   DIYnot > Forums
Local | Network
myson kick sapce heater not blowing hot hair/ heating
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
hothedz
from United Kingdom
PostPosted: Fri May 02, 2008 8:03 am Reply with quote
i have a myson 500 kick space heater that is plumbed into the central heating system, it is 2 yrs old and was working before we had the kitchen renovated and a new central heating system installed new bolier/rads.
Now one year on it has now been refitted but it wont give off any heat.
It works fine on the cool setting fan turns cold air is blown out.
but on the warm setting low and high, it only seems to kick on when it wants to i have timed it to be every 3-5 mins and it stays on for around 3- 40 seconds, the fan turns but only cool air is blown out and it turns off again after 40 seconds or so..
I have tried turning the air release valve on the left h/s at the front by the vent and just water comes out. i have tried swaping the flexi hoses around
i noticed that the top hose is getting hot water as i can feel it, and bottom one has cold water running through it , all the other rads in the house are all hot and working fine .
Should it have fitted it with its own external thermostat
thanks
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Fri May 02, 2008 12:07 pm Reply with quote
Probable airlock in pipework to it turn heating on and all other rads off and try and force it through
Back to top
 Alert Moderators
LUNAT
from United Kingdom
Thanked: 22 times
PostPosted: Fri May 02, 2008 6:40 pm Reply with quote
HI
it sounds like circulation problem.try turning off all rads and turn the heating on.remember it only blows hot air once the pipe (are hot) sensor is activated.check if sensor is fitted correctly.
Back to top
 Alert Moderators
WDIK
from United Kingdom
Thanked: 56 times
PostPosted: Fri May 02, 2008 6:54 pm Reply with quote
probabley the hold off stat or as said a lack of circulation.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fuze blowing when central heating kick ins 7 480 Mon Jun 04, 2007 11:28 am
combi heater won't kick in , Vaillant vcw 18 t3w 24 1840 Tue Apr 13, 2010 8:19 pm
smiths kick space heater 2 500 Mon Feb 02, 2009 8:38 pm
water ok but heating won't kick in (electronic prob poss?) 4 161 Mon Jan 03, 2011 11:06 pm
Salamander pump won't kick in without lowering shower head 28 3340 Mon Apr 28, 2008 3:01 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
