hi, on which tank would i need to "tie up" ball valve to enable me to drain down c/h system...in my loft i have 2 tanks..one is the big main water tank..but just behind that one is a much smaller tank ( i belive it could be called the header tank..having read in the wiki and i quote.......
"Vented System
As above but firstly you should tie up the ball valve to a plank of wood placed across the cistern to cut off the water supply. To refill, simply untie the ball valve. Don't forget to add inhibitor and bleed rads. "
would my system be a VENTED SYSTEM?(i have no idea )..if so...do i tie up the ball cock in the biggest tank to cut off the water c/h system rads to enable me to drain down my system, many thanks in advance
"Vented System
