Hi
I'm in a perculiar position of having to fit self closers to my 'protected route' even though I understand they are not now required under the post April 07 rules...
My application for a loft extention was submitted a week prior to that in March 07-presumably so the builder could create an escape window in the loft and not have to do a protected route?? However an escape window proved impossible so we had to go 'protected route' anyway which I have tackled myself.
The BCO has checked the work and all is fine except he has asked for closers as he is working on pre April 07 rules-which is fine (although seems illogical)
I've looked at the perko type ones as they seem to be the most cost effective way of doing it-has anyone any advice on the following;
1. Are there any criteria on the height at which they should be fitted?
2. Do the fire doors have a solid block on the hinge side that it would be best to hit? The perko closer looks to be about 6" long...
3. Does the closer have to make the door 'latch' for it to pass?
4. Are they straightforward to fit like a mortice or are they fiddly?
Thanks all-first post apols if have rambled on a bit!!
Cheers
Cheers
