CREDA Electric 9.5kw Shower
18 May 2008
The water in my CREDA Electric 9.5kw shower suddenly stopped. The low pressure light is on and the lights on the dial control illuminate as soon as I turn the shower on at the power source not the button on the shower. The dial lights never used to illuminate until the shower was turned on with the button on the shower appliance itself. The water pressure in all the other taps in the house are fine.
Any help on this?
Thanks for taking an interest in my problem, it's appreciated but I wouldn't know where to start and do a test like that. If it's a complex as that I suspect I'll have to get someone in to do that.
not never fitted a creda shower before they are all basically the same inside.
but you say the lights are coming on before you switch the shower on button which sounds like a faulty on/off button or a short causing the main problem
Thanks very much. I'll switch the power off at the mains supply and check the wiring is okay. I'll come back and let you know how I get on...I hope.
:rolleyes:
Once again thanks for taking an interest.
