DIYnot
Local | Network
   DIYnot > Forums
Local | Network
drip from toilet water inlet
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
CanIEat
from United Kingdom
PostPosted: Sun May 18, 2008 11:17 pm Reply with quote
Hi. I installed a close coupled toilet. There is a drip from the compression fitting between the pipe and the inlet of the toilet. I'm not sure there's meant to be an olive in there or not. The size of olive that comes with 15mm compression fittings doesn't fit in the plastic threaded part of the inlet to the toilet. But the 15mm nut is the correct size.
I've tried without the olive and with it stuck in as much as i can get it. It drips either way. Anyone got any ideas what's wrong?
Cheers
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1097 times
PostPosted: Mon May 19, 2008 10:05 am Reply with quote
Wrap the olive with a few turns of ptfe if it's too small.
If the spigot sticking out of the fill valve is square ended, you need a tap connector, or better, an appliance service valve.
Back to top
 Alert Moderators
Whitespirit66
from United Kingdom
Thanked: 607 times
PostPosted: Mon May 19, 2008 10:55 am Reply with quote
Do you mean the connection where the copper water pipe joins the plastic thread for the float valve?
If you do, then this isn't a compression fitting, its a half inch tap connector.
You will need a half inch fibre washer to go on the bevelled end of the connector inside the nut. This forms the seal between the tap connector and the plastic threaded float valve tail.
Back to top
 Alert Moderators
CanIEat
from United Kingdom
PostPosted: Tue May 20, 2008 12:22 am Reply with quote
Yes, this is where the drip is coming from. I'll try fitting a half inch tap connector. Thanks for your advice.
Back to top
 Alert Moderators
Goldspoon
from United Kingdom
Thanked: 33 times
PostPosted: Tue May 20, 2008 6:45 am Reply with quote
And no need to overtighten and take care not to damage the thread on the inlet valve which is usually plastic.
Back to top
 Alert Moderators
Whitespirit66
from United Kingdom
Thanked: 607 times
PostPosted: Tue May 20, 2008 10:29 am Reply with quote
If you have connected up to the plasic float valve tail, then you must already have a tap connector in place.
Its the fibre washer you need.
Back to top
 Alert Moderators
CanIEat
from United Kingdom
PostPosted: Tue May 20, 2008 11:22 pm Reply with quote
15mm compression x 1/2 inch tap connector with fibre washer now fitted, and no leak!
Thanks for your help.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
New toilet instalkled and a small drip! 5 260 Sun Aug 23, 2009 10:45 am
toilet button is stuck and shower mixer drip 9 660 Sun Oct 26, 2008 8:16 pm
Close coupled toilet drip 6 100 Thu Sep 08, 2011 5:29 pm
Electric Hot Water Cylinder - Drip from overflow pipe. 2 380 Sun Jun 21, 2009 7:10 am
Drip from the Hot Water Cylinder 9 460 Mon May 04, 2009 9:58 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
