Joined: 20 May 2008 Posts: 12 Location: United Kingdom Thanked: 0 times
Posted: Tue May 20, 2008 8:54 pm Post Subject:
Light switch route - is this legal?
Hello, hope someone can help...
We've had some work done by an (experienced) electrician. Part of this was to move a light switch to a new position to the right. It was previously in the middle of a wall with the cable chased into the wall going vertically upwards from the switch. He moved the switch by connecting a new cable into the old back box, and running it horizontally to the new switch position.
This doesn't seem right to me. Although the new (horizontal) cable is in a safe zone, the old drop of cable to the old metal back box no longer is (or won't be once the new cable and old metal box are plastered over!). Not to mention the inaccessible connection in the wall! He says it's all fine and we can plaster/decorate, but I don't agree.
Who is right?
Joined: 11 Jan 2004 Posts: 16485 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Tue May 20, 2008 9:01 pm Post Subject:
It is only safe if the old switch box has a blank plate fitted, thus indicating the presence of cable. Shouldn't really be plastering over old switch boxes. Is there a join in the cable?
__________________ As George Michael once said, "..if you're gonna do it, do it right, right?"
Posted: Tue May 20, 2008 9:08 pm Post Subject:
That was quick, thanks!
Yes, old and new cables joined in the old metal box with those plastic terminal blocks, and a bit of polythene covering this 'ready' for plaster!
I admit we didn't say to him "We want a new cable vertically upwards from the new switch", etc - we expected him to follow regs. He knew we wanted everything chasing in (as he has) and no blanking plates.
Posted: Tue May 20, 2008 9:26 pm Post Subject:
Thanks for your replies.
Is re-routing this cable (to run vertically from new switch) a notifiable job (am I allowed to re-route it myself with no Part P as a DIY-er?) Might be the easiest way if I am...
Joined: 19 Sep 2007 Posts: 116 Location: Staffordshire, United Kingdom Thanked: 0 times
Posted: Thu May 22, 2008 8:02 am Post Subject:
As the 17th edition update says - stick a cable anywhere as long as it has rcd protection .. ( forgive me for paraphrasing !!) i think the real problem here is the fact he has made a join that when plastered over wont be accessible for inspection.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
