window wont lock
23 May 2008
Berkshire
I have a UPVC window, when I close it and turn the handle in to the lock position it does not lock, and if you push the window it opens. Is this something I cna fix myself? I have tried a different handle but this did not work and oiling the parts did not work either. Any other suggestions?
with the window open,try operating the window handle and see if the rollers/bolts on the window move,if they dont then the mech is most likely faulty and will need unscrewing and replaceing,there not expensive.
if they do move then check on the frame to see if there are striker plates on there for the rollers/bolts to lock into,if not,they will need sourcing and replacing.
thank you. Have checked and the bolts dont move so it must be the mechanism. Going to try and find a match. Thank you
