Garage Side Door
10 Apr 2008
Kent
The side door of my garage needs replacing. Where do I start to look for a new one?
I have been to B&Q and garden centres with no luck. Anyone any wiser??
It is just for the side door of my garage.Timber door 2m x 75cm.
Do you think is would be ok for glass bits in the door?
The door I have at the moment just has wood panels? I thought the door might be a bit different to a normal external door. Sorry about the silly questions but as you can tell I am very new to this.
glass panels in the door make it extra-easy to break in
the big advantage of a personal door on a garage is that you can then fit a strong "front door" with a proper strong lock, and use it to go in and out of the garage, and you can fit the big car door with extra bolts that you operate from inside (big garage car doors are very easy to force and manufacturers' locks are not much good)
edited: the little fanlight glass at the top is a good idea, as not easy to climb through or get at the lock, or even peep through to see what you've got that's worth having.
Thanks for all the replies. I was hoping to find somewhere that sells cheap doors. The garage is an external garage next to my house. I am not really that worried how secure it is as all that is in there is what would be in a shed plus a few kids bikes.
Thanks anyway.
