DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Clicker Bath Waste Leak
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
sheslookinhot
from United Kingdom
PostPosted: Sun May 25, 2008 11:56 pm Reply with quote
I wonder if you can give me some advise.
I installed a new bath with Clicker waste. I had two leaks,
1) first leak from the bath trap / clicker waste seal. I fitted a new o-ring and gave it a few more turns seems to be OK.
2) second leak appears to be coming from the backnut/ clicker waste body thread. The seal immediately below the bath appears good, the seal below and above the banjo appears good.
Can I solve this leak by applying a bead of silicone Dow Corning 785, around the thread before I wind up the backnut ?
Back to top
 Alert Moderators
Goldspoon
from United Kingdom
Thanked: 29 times
PostPosted: Mon May 26, 2008 7:02 am Reply with quote
I would use Plumbers Mait (can get B&Q or Plumber's merchants) - wipe around all thread before screwing nut on.
Back to top
 Alert Moderators
solo
from Albania
PostPosted: Mon May 26, 2008 7:22 am Reply with quote
DON'T use plumbers mait.
Back to top
 Alert Moderators
Goldspoon
from United Kingdom
Thanked: 29 times
PostPosted: Mon May 26, 2008 8:20 am Reply with quote
I'm sure the reason why would be appreciated by the OP. Or an idea of what is best.
I was shown to use Plumber's Mait by a plumber with over 40 year's experience but am all ears.
Thanks in advance.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
difference between clicker waste and pop up wast 2 1400 Tue Oct 31, 2006 6:54 am
Clicker basin waste does not close 4 260 Sun Sep 05, 2010 11:36 am
Emptying bath causes leak through washing machine waste pipe 3 120 Tue Aug 16, 2011 8:02 pm
bath waste leak 3 2100 Tue Jul 25, 2006 8:49 pm
Bath waste: overflow tube leak 3 980 Wed Aug 15, 2007 8:01 am
DIYnot
