How Can I Verify My Landis & Gyr RWB2 Programmer Is Faul
27 May 2008
Kent
I suspect my Landis & Gyr RWB2 Programmer to be faulty as my HW is working fine but I have no CH. I have tested the room thermostat, pump and 3 way valve which are all working fine.
Does anyone know which contacts I can short on the backplate to bypass the programmer and see if the CH fires up to confirm if it is the programmer at fault?
Rod
Terminal 4 is the CH ON terminal; so if you link this to the L terminal you will bypass the CH side of the programmer and the boiler should then work (providing it is not something else ;) )
Thanks, that worked a treat :D
I'm off to buy a new programmer now.
Rod
