DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing Satchewll TLX 2259 Room Thermostat
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
steveg2
from United Kingdom
PostPosted: Wed May 28, 2008 6:07 pm Reply with quote
I am replacing a Satchwell TLX 2259 (Dial operated) with a Sunvic TLX7501.
Am I right in the fact that Sunvic took over Satchwell as all forum searches seem to point to the Sunvic TLX 2259 ?.
The TLX 2259 has yellow - terminal 1, red - terminal 3 and blue terminal4.
The TLX 7501 has terminal 1 - OFF, terminal 2 - ON and terminal 3 - C.
I am bit confused with connecting to the new terminals and I was wondering if anyone could help me please.
Back to top
 Alert Moderators
andy212
from United Kingdom
PostPosted: Wed May 28, 2008 6:30 pm Reply with quote
Hi the tlx 7501 has no neutral so you conect red to terminal 3 and yellow to terminal 2 and make safe the neutral in conecter block.
Back to top
 Alert Moderators
steveg2
from United Kingdom
PostPosted: Thu May 29, 2008 9:31 pm Reply with quote
Thanks for the information, it has been installed and working fine.
Back to top
 Alert Moderators
McToon
from United Kingdom
PostPosted: Thu Aug 14, 2008 6:39 pm Reply with quote
I'm also trying to replace a Satchwell TLX 2259 with a Sunvic TLX 7501.
On my set up I have 3 wires coming out of the wall. An earth attached to the back plate, 1 Red and 1 Black each attached to a terminal on thermostat. The difference for me is that there is an additional electronic component (with markings: Z5U, 01Z, IKV) linking the 2 terminals Red and Black.
I've tried simply connecting Red to 3 and Black to 2 on the 7501, but it doesn't work!!!
Do I need to link them with this extra component???
Back to top
 Alert Moderators
spikboy
from United Kingdom
PostPosted: Wed Nov 25, 2009 11:48 am Reply with quote
To add to this (I have just joined and fully intend to use this forum properly) I have a satchwell tlx2259 and want to replace with a sunvic 7501. The issue I have is that the current config on the Satwell is Blue wire-1, Brown wire-3 and the yellow/green is made safe.
This seems incorrect to me in terms of best practice?
Back to top
 Alert Moderators
spikboy
from United Kingdom
PostPosted: Wed Nov 25, 2009 1:00 pm Reply with quote
I used my brain a little harder and connected Brown to C-3 and Blue to 2-on. all good now.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replacing Satchwell TLX 2259 Room Thermostat 14 3580 Fri Aug 27, 2010 11:03 am
Replacing Sunvic TLX 2259 3 120 Sat Jan 11, 2014 2:44 pm
Wish to replace satchwell TLX 2259 3 40 Tue Mar 06, 2012 12:21 pm
Replacing old room thermostat with Horstmann DRT1 2 40 Wed Nov 13, 2013 2:59 pm
Replacing Room Thermostat 6 140 Sun Oct 06, 2013 10:45 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
