DIYnot
Local | Network
   DIYnot > Forums
Local | Network
working pressure
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
alan99
from United Kingdom
Thanked: 257 times
PostPosted: Fri May 30, 2008 1:17 pm Reply with quote
hello. i had a working pressure at the meter of 14 mb . but the gas rate on the gloworm compact 100e was fine , totally unaffected. transco came repaired but just wondering how can such a low pressure not affect the gas rate on the boiler??
Back to top
 Alert Moderators
Nixt
from United Kingdom
PostPosted: Fri May 30, 2008 2:06 pm Reply with quote
Because you're confusing working pressure with burner pressure.
Back to top
 Alert Moderators
alan99
from United Kingdom
Thanked: 257 times
PostPosted: Fri May 30, 2008 3:17 pm Reply with quote
standing pressure at meter was 16 and working pressure at the meter was 14mb. this would surely dramatically effect the inlet pressure to the appliance and thus burner pressure and gas rate. both burner press and gas rate spot on
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 422 times
PostPosted: Fri May 30, 2008 3:25 pm Reply with quote
are you saying BP is higher than working pressure at meter
Back to top
 Alert Moderators
spudkey
from United Kingdom
Thanked: 210 times
PostPosted: Fri May 30, 2008 3:32 pm Reply with quote
it depends on the burner pressure setting on appliance, i think on this boiler it is only about 14mb anyway, if it needed a higher burner pressure then having only 14mb inlet will effect combustion & gas rate if required burner pressure is not achiveable it also becomes at risk
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 422 times
PostPosted: Fri May 30, 2008 3:53 pm Reply with quote
thats why I checked MI, 14.3mbar (hot)
Back to top
 Alert Moderators
spudkey
from United Kingdom
Thanked: 210 times
PostPosted: Fri May 30, 2008 4:07 pm Reply with quote
ah! 14.3mb burner pressure but only 14mb at meter, yet Op states burner pressure spot on i see your point
Back to top
 Alert Moderators
alan99
from United Kingdom
Thanked: 257 times
PostPosted: Fri May 30, 2008 5:25 pm Reply with quote
THANKS. yes off course if the burner pressure max setting is say 12mb and meter working pressure is say 16mb then the bp of the aplaince wont be affected. common sense i guess . thanks chaps
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 422 times
PostPosted: Fri May 30, 2008 6:43 pm Reply with quote
but you said WP at meter 14mbar, BP spot on, (MI say 14.3mbar) how is this so, or are you taking wrong readings or being given wrong info by the RGI that tested it
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 925 times
PostPosted: Fri May 30, 2008 7:46 pm Reply with quote
has anyone seen the OPs previous questions. it sounds like hes trying to fault find and work on gas sorry if im reading wrong.
Back to top
 Alert Moderators
assured heating
from United Kingdom
Thanked: 28 times
PostPosted: Mon Jul 28, 2008 8:45 pm Reply with quote
yes it seems that alan99 has been asking questions that are really basic !! that is what the fast track system is giving to the industry GOD HELP HIS CUTOMERS icon_rolleyes.gif
Back to top
 Alert Moderators
spacethegas
from United Kingdom
Thanked: 2 times
PostPosted: Mon Jul 28, 2008 10:03 pm Reply with quote
get out transco then.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Working pressure and pressure drop across system 2 580 Sat Dec 22, 2007 4:43 pm
Low Water Pressure, shower not working 5 340 Mon May 02, 2011 10:56 am
Different opprating and working pressure 4 80 Tue Feb 25, 2014 8:10 am
Pressure gauge not working on Vaillant ecotec pro 28 12 140 Wed Feb 19, 2014 7:01 pm
Worcester 28 CDI, pressure gauge not working 7 80 Sat Apr 07, 2012 5:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
