grundfos pump screw - how to turn it!!
6 May 2008
London
just fitted my new towel rad after draining the system, now going to refill it and will bleed rads in doing so, and manual air vent next to the HWSV. but how do i bleed my pump?! It is a grundfos 15-50 and has a circular slotted screw at the front, but no screwdriver (even a big one) fits it and allows it to turn! any tips please ... ?
Don't bother bleeding the pump unless it fails to clear the trapped air...it's very rare you need to.
Get yourself a proper screwdriver...sounds as though you have something cheap with a thick blade.
I hope you thoroughly flushed through the towel rail before fitting it...they are notorious for containing vast amounts of mill scale that won't do the system anygood.
yep i flushed it through first with a hose and then connected it. now going to act somemore sentinel x100 to my system again on refilling!! I have some stanley screwdrivers, not cheap cheap ones. the screw just wouldn't seem to budge!!
You're probably just a bit limp wristed :) Fill up the system fist...unless it's poorly designed you shouldn't have a problem.
lol believe me i'm not weak!! i just didn't want to force it too much as the screw was getting a bit scratched and stuff and i didn't want to break anything!! :)
just bled it (in the end) and a little water came out, but when i have tightened the screw up again a bit of water dribbles out of the grundfos black sticker/thing on the front of the pump!!! why is this, will it stop??!
don't know what happened there but it has stopped now (touch wood)!! as the poster before said though, the pump didn't really need bleeding, just the rads.
