Potterton Suprima 30......again!
23 Jun 2006
Merseyside
Hello all,
sorry if this is a bit long but here goes.........
My son and his girlfriend have recently moved into a house built in 1999 with a Suprima 30 installed as it's CH Boiler.
When power is applied to the unit (from a switched fused spur) the Green & Red LED's light up for a short time and then the Red LED begins to flash and the unit refuses to light up when HW and/or CH is called for.
With the cover off, I noticed the fan gives a kick on start up but nothing else, the overtemp sensor (white wires) is not o/c, and the APS (orange wires) is o/c (cos the fan isn't running?) The temp sensor (thermistor?) shows a resistance which does vary a little if I get hold of it.
I've removed the PCB and tried resoldering the main joints on it (as has been advised many times before i've noticed!!) but replacing the board and powering up hasn't altered anything.
There is an audible click from one of the relays on the board when I press the rest button and the 2 LED's cycle on and off with the Red one left flashing
I expect this is down to a faulty PCB, but if possible i'd like confirmation that this is the most likely problem before I get a replacement board.
What's irking me is that most of the problems i've seen relating to the PCB come after it's fired up whereas this one isn't even trying.
It has only two LED indicators and a reset button and these are mounted to the right side of the unit. It's GC number is 41 607 75.
Thanks in advance for any assistance on this.
PCB problems are very common on that boiler model.
If everything else has been correctly checked then it must be the PCB.
Why does your son not want to accept the fact thet the boiler needs a repair?
The manufacturers fixed price repair is probably the most economic.
Tony
Thanks very much for your reply, Tony.
My son does accept there is a repair to be done, (that's the reason i'm looking at the problem for him :) )
He's not very technically adept though, I am more so, but without enough info to make a specific diagnosis, hence my original post.
It would appear that most of the ills on the 30 are PCB related.
I think i'll get a new PCB and fit it.
regards
Dave
