We have recently had the pump changed seems to work fine. Have a Potterton EP3001 switch which looks like it is working ok, timer correctly set, but the pump will not turn off when heating the hot water, even when we push the off button, the hot water light goes off so you would expect the pump to stop but it doesn't. We are having to turn it off at the mains in order to stop the water getting too hot.
Any advise would be much appreciated.
