Hi My machine dial is clicking around constantly and when you put it to drain and spin it start to pump but then stops and starts clicking again
I've had the machine out and cleaned all of the pipes etc and all is ok that end. The machine will fill with water no problem at all.
Does this sound like a pump blockage to you?? Any help would be greatly appreciated !
A friend has also said this could be down to an "elastic band" part (not sure of the technical term!) and would only take minutes to replace.
