A long shot I know but is anyone out there knowledgeable about these boilers? It is a Potterton Suprima 40L
My problem is that the central heating works fine but the hot water, however, doesn't heat up at all. When I turn it on using the wall panel, the red light stays (not a lock out) on and nothing happens, no noise, no anything. It's like the temperature is already what it should be.
What's confused me more though is that the small temperature knob on the boiler unit it turned up and when I turn it down I hear the "click" noise which indicates the current temperature - very low!
As you may have guesed I have the technical know-how of, well, a cabbage so if it is something like the thermister then a point to the right direction to help replace and fit would be massively appreciated!
Thanks in advance!
More info:
System and House is approx 6 years old
Water tank upstairs is a Santon Premier
Thanks in advance!
More info:
