DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to fit door under the stairs.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
robowen
from United Kingdom
PostPosted: Wed Sep 22, 2004 3:01 pm Reply with quote
Need to fit door and frame under the stairs. Pretty good at diy. Frame not a problem to build with standard door casing wood.
don't know how to start the project, or where to get a small door from.
I have an approximate opening of 710mm x 1220mm high. The door casing will go inside the wall and the newell post of the stairs, not sure if to cut frame into skirting board or cut the back of frame to skirting board profile.
Any help much appreciated, especially links to site supplying small doors.
thanks
mike
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Wed Sep 22, 2004 4:55 pm Reply with quote
Depends if the skirting board is a pine or varnish finish then cut the skirting board to the frame ( you may find it easier to removed the skirting board) and if it's painted then you could cut the frame round the skirting then make goods plus paint.
You maybe better off to try and make the door to the size you want instead of looking for the nearest size you can get.
There are many way to make a door, mdf with a router finish, a frame with internal T&G, a frame with wallpaper insert to match the decor, a mirror door and so on.
Back to top
 Alert Moderators
robowen
from United Kingdom
PostPosted: Thu Sep 23, 2004 12:41 pm Reply with quote
everything is wood varnished. dont want to pull skirting off if I have to. just had plastering done and painted all round. not sure about routing mdf as I dont have the tools for that job. would be happy with a simple door with a hardwood finish to it, but cant find door blanks anywhere local to manchester. Is it an easy job to make a door from a couple of sheets of marine ply with battons internally for frame and lock. ? how would I make the edge of the door look like its supposed to ??
basically.....how do I make a door ??
thanks
mike
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 957 times
PostPosted: Thu Sep 23, 2004 2:15 pm Reply with quote
helllooo robowen
without a router your restricting your option
you could make it with a softwood [2by 1] 20mm 2x6mm faced ply=32mm
then you would need 6mm hardwood edging say 6mm by 32mm
to cover all exposed edges
big all
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Under the stairs door 2 740 Mon Mar 06, 2006 2:15 pm
Door for under stairs? 3 120 Thu Oct 16, 2014 8:50 am
Maximum door opening width - french door options! 4 2060 Sun Mar 18, 2012 7:41 pm
Where to scource UPVC door hinges 3 120 Tue Mar 20, 2012 5:25 pm
Door ideas for a 3.8M opening! 4 120 Fri Mar 16, 2012 2:51 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
