DIYnot
Local | Network
   DIYnot > Forums
Local | Network
I want to build a small porch - please advise / comment
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
seanxkelly
from United Kingdom
PostPosted: Fri Jun 06, 2008 10:41 am Reply with quote
My house could do with a porch - something to keep the pushchair and outdoor shoes in. I have DIY experience and feel this is something I want to attempt myself.
I'd like some comments on where/how to start and any advice for getting the work done.
So, some details:
- step down from front door to existing path: 6inches
- desired dimensions: 1.5m (way from house) x 2m (along existing exterior wall including current front door)
Does this sort of thing normally need planning permission?
How big should the foundations be?
That sort of stuff.
Many thanks!
Sean.
Back to top
 Alert Moderators
Delinquent
from United Kingdom
PostPosted: Fri Jun 06, 2008 1:32 pm Reply with quote
Assuming a "normal" sort of single height, that's going to have a volume of < 10 m^3 - so will most likely fall under permitted development providing you haven't already used up your entitlement with other extensions. (you have to subtract the volume of existing / other extensions from the volume of the "original" house, then if it's not in a conservation area or anything like that it's up to 15% increase in volume as PD.) If you want to be on the safe side drop a sketch of your intentions to the duty officer and ask them to confirm it in writing.
Haven't got a clue on the rest, that's the sort of question I've been asking on a daily basis icon_biggrin.gif
Back to top
 Alert Moderators
chessspy
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jun 06, 2008 2:32 pm Reply with quote
Hi, Sean,
If the porch is going on the front of the house, that means it will alter the building line and will certainly need planning.
The footings need to be commensurate with the house founds, (means a similar depth)
If you're going for 4" brick or blockwork, as it will be non hab. (if the front door is being left on).
You will probably need building regs anyway.
Will you be covering up or altering and gullies or drains, will you cover any air bricks? Where will the water off the roof go? how do you plan to tie it in to the existing house?
All questions you need an answer for before approaching the council for permissions.
Back to top
 Alert Moderators
Delinquent
from United Kingdom
PostPosted: Fri Jun 06, 2008 2:37 pm Reply with quote
Oops - forgot about that sticky out bit icon_redface.gif Think I best stick to asking the questions...
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Fri Jun 06, 2008 9:21 pm Reply with quote
a porch does not require b.c. approval.
also, if the roof is less than a certain size (less than 4m2 or so) then the rainwater can be allowed to run off the roof without collection, if you so wish. or collected in a gutter and down-piped onto the ground.
having seen what prolonged driving rain and extremes of cold can do, i would be inclined to build the wall as insulated cavity wall.
found's need to be on good undisturbed (virgin) ground. excavations need to be deeper than all fertile matter.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Fri Jun 06, 2008 11:19 pm Reply with quote
Noseall is totally correct; a porch doesnít need either PP or building regs. providing you keep the original front door (or an external door) between the porch & the main property & that you donít heat the porch. PP will only be required if your Council has removed your permitted development rights (based on previous planning consents) or has taken these rights away throughout the area (called an Article 4 direction) then you can build a porch regardless of how many extensions the property has previously had.
Guys if your not 100% certain of your facts, don't post incorrect info as it just confuses everyone! icon_rolleyes.gif
Back to top
 Alert Moderators
tony1851
from United Kingdom
Thanked: 847 times
PostPosted: Wed Oct 10, 2012 7:55 pm Reply with quote
chessspy wrote:
Hi, Sean,
No. If the porch is 1) less than 3 sq m floor area; 2) not more than 3m high and 3) not nearer than 2m to the back of the footpath, it will NOT need planning permission (assuming not listed building;no withdrawal of permitted developmenbt rights etc etc).
Also would not require any building regs. application.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1596 times
PostPosted: Wed Oct 10, 2012 8:26 pm Reply with quote
Tony, this old thread was raked up by spamhead jugears.
Back to top
The following user says thank you to freddymercurystwin for this useful post:
tony1851 (10 Oct 2012)
 Alert Moderators
Moderator 8
Moderator Comment
Posted: Wed Oct 10, 2012 8:28 pm    Comment:
As fred says, this old thread was ressurected by a spam post which I have now removed.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
RSJ installed badly? - Please comment on photos 36 4220 Sun Oct 31, 2010 4:17 pm
Please comment on my basement excavation plan. 2 120 Tue May 08, 2012 6:10 am
Would a home buyers survey comment on wall construction 9 220 Sat May 09, 2015 7:55 am
Cavity wall insulation DIY small job - advise please. 5 820 Sat Mar 29, 2008 9:39 pm
Single skin or double skin front porch - please advise. 2 480 Sun Apr 18, 2010 9:32 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
