DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fixing gate post to brick wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
Author Message
mikeymo
from United Kingdom
PostPosted: Tue Jun 10, 2008 1:13 pm Reply with quote
Maybe not the right forum, but here goes.
I'm fixing a garden gate to the house wall. The gate will be about 6 feet tall by 4 feet wide. It'll be in timber, and heavyish.
The wall it'll hinge 9 inch solid brick wall. So I thought I'd use a piece of 3 x 2 fastened to the wall. And fix the hinges to that.
What I'm pondering is the best way to fix the 3 x 2 to the wall. ALL the weight of the gate will be on this. There won't be any sort of cross piece at the top, so the gate will be trying to pull the post away from the wall. And of course there will be a small amount of lateral movement every time the gate opens and closes.
I thought first of all to use 4 x 2 to reduce the lateral movement. I alos want the thing to be demountable in case I change my mind, need a new post or whatever.
And ideally I'd like to not leave anything in the wall. I can't go right through the wall (even if I wanted to) as it's on a corner.
I've never used shield anchors and such like. But something like this:
http://www.powers.com/pdfs/mechanical/07246.pdf
looks like the business. Is there a UK version? Anybody used them? What success?
The wall is redbrick. And pretty solid. I don't think they're actually engineering brick, but I thought it was just me being a wuss until I started employing electricians and plumbers who all complained how hard the brickwork is. So hopefully I can get a pretty secure anchor.
Cheers
Back to top
 Alert Moderators
xerxes
from United Kingdom
PostPosted: Wed Jun 11, 2008 8:40 pm Reply with quote
If you want the post to be readily demountable, I would use a shield anchor bolt like this .
It sounds like you need a decent SDS drill to make an impression on those bricks.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1123 times
PostPosted: Wed Jun 11, 2008 10:31 pm Reply with quote
I think you're over complicating the job.
Some [nr 12] screws and [brown] plugs will do this perfectly, or some [8 or 10mm] hammer-fix or frame-fix plugs will be more than enough.
4 fixings of 50mm into the wall will do it
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 3 times
PostPosted: Thu Jun 12, 2008 2:08 pm Reply with quote
I agree with woody, too complicated.
Go get a pack of these which will be more than adequate
http://www.wickes.co.uk/Fixings-Frame/Frame-Fixers/invt/510062
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Fixing Wood to Brick - Totally Stalled 4 320 Wed Jul 06, 2011 9:36 am
Stud lining a single brick exterior wall - pitfalls? 3 680 Sat Sep 05, 2009 9:54 am
Fitting skirtings to brick wall 5 1040 Wed Sep 19, 2007 9:18 am
Advice for attaching shelves to brick wall w/out cleats 3 100 Fri Jan 20, 2012 4:15 pm
How do I fix skirting boards to a brick wall? 8 6820 Mon Dec 10, 2007 11:58 am
DIYnot
