polycarbnated panels
10 Jan 2007
which poly panels 25mm are the best 4 allowing light in , customer is looking for seeing as much as possible with poly panels
any help would be appreciated
Clear ones! :LOL: The amount of glare & heat transfer will be horrendous though, especially if south facing! If it's a new cons, I would go a lot thicker than 25mm; you can get up to 50mm now, much better at reducing heat loss! ;)
You wont see much through any multi-wall panel - they are all obscure
Agreed; if the lady want's to “see the stars”, she needs a glass roof but that will basically turn the cons. into a greenhouse during the day!
