Have tried to fit a new wall light and i cant get the thing to work. Where am i going wrong?
I have 2 cables coming out the wall. 1 is the switch and 1 for the actual light.
I have used a 4 way connector block. From left to right are numbered 1,2,3 and 4.
1. Connected the 2 red (live) wires into the same end. 1 from each cable.
2. Connected the earth from the cables in one end and the earth from the light to the other side of the connector.
3. Black neutral from the light cable in one end and the blue wire from the light to the other end.
4. Black wire from the switch cable and connected the brown from the light to the other end of this connector block.
Once electricity is back on the lights are on but the switch does not turn them off and does nothing else.
Can anyone tell what the problem can be. Thanks in advance!
